1000V Output, No-Opto, Isolated Flyback Converter for High Output Voltage Applications
Isolated flyback converters are used in automotive, industrial, medical, and telecom applications where the power supply must be reliable, easy to use, high voltage, and isolated, and they must provide excellent regulation over load, line, and temperature. LT8304-1 is an isolated, no-opto flyback converter optimized for high output voltage applications that provides outputs up to 1000 V.
This is a companion discussion topic for the original entry at https://eepower.com/power-converters/1000v-output-no-opto-isolated-flyback-converter-high-output-voltage-applications
