SubscribeEE Power
Film capacitors for high-voltage applications: high performance under maximum load
#1
The Husum-based company FTCAP is one of the few manufacturers of high-voltage capacitors: These special film capacitors are available for voltages of more than 120 kV DC, which makes them ideal for use in medical devices, high-voltage power supply units, or even body scanners for building security. The product spectrum offered by FTCAP includes numerous versions with different housing forms and connection technology, including radial designs with wire and solder lugs.
This is a companion discussion topic for the original entry at https://eepower.com/passive-components/film-capacitors-high-voltage-applications-high-performance-under-maximum-load
