Specializing Performance: Collaboration Gets it Right with Custom Power Magnetics
Off-the-shelf magnetic components are often a compromise solution for any application, both electrically and mechanically. To achieve ideal performance at minimum cost, custom inductors or transformers may be a better alternative, with the greatest benefit realized when user and supplier work together closely. Headline specifications such as inductance, turn ratios, and resistance are only part of the story; expertise helps identify other relevant parameters critical to tooling options for the right fit components from the outset of the design.
This is a companion discussion topic for the original entry at https://eepower.com/magnetics/specializing-performance-collaboration-gets-it-right-custom-power-magnetics-tt-electronics
